Ga door naar hoofdinhoud
Shark Rotator Powered Lift-Away Speed Belt Replacement
Wat je nodig hebt
  1. Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: stap 1, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: stap 1, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: stap 1, afbeelding 3 van 3
    • Turn the vacuum on its side.
    • Using a quarter, twist the three green locks to the unlock position.
    • Pull the bottom roller brush cover to open the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 2, afbeelding 1 van 1
    • Using a T20 screwdriver, remove the five 15.9 mm screws on the outside cover.
  3. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 3, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 3, afbeelding 2 van 2
    • Remove the three 14.3 mm screws with a T20 screwdriver.
  4. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 14.3 mm screws under the wheels with a T20 screwdriver bit.
  5. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
  6. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 6, afbeelding 1 van 1
    • Remove the single 13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
  7. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 7, afbeelding 1 van 1
    • Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
  8. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 8, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 8, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 8, afbeelding 3 van 3
    • Turn the vacuum around.
    • Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
  9. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 9, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 9, afbeelding 2 van 2
    • Remove both of the headlight covers with the spudger.
  10. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 10, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 10, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 10, afbeelding 3 van 3
    • Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
  11. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 11, afbeelding 1 van 1
    • Remove the two 13.4 mm screws with a T20 bit screwdriver.
  12. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 12, afbeelding 1 van 1
    • Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
  13. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 13, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 13, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 13, afbeelding 3 van 3
    • Remove the visible side of the belt from the gear with a spudger.
  14. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 14, afbeelding 1 van 1
    • Remove the grey panel from the opposite side, by uncrewing the single 13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
  15. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 15, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 15, afbeelding 2 van 2
    • Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
  16. Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 16, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Belt Replacement: stap 16, afbeelding 2 van 2
    • Remove the belt from the gear.
Conclusie
Dakota Rodriguez-Ransom
605 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G6, White Fall 2018 Lid van Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Leden
12 handleidingen geschreven
2 opmerkingen
Where can we buy belts in UK?
Greg Norman - Antwoord
where cn i get a belt for this vaccum
Annie Pappineau - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 25
Afgelopen 7 dagen: 202
Afgelopen 30 dagen: 939
Altijd: 38,233
