Inleiding
When the Shark Rotator Powered Lift-Away is difficult to maneuver or fails to pick up dirt, inspect the roller brush for clogs or damage. Excessive obstructions will cause the vacuum to not operate as intended.
Wat je nodig hebt
Push the lift away button and pull the handle up to separate the body from the wand section.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
The 13 Philips screws are Torxt 25 screws not philips head screws it’s a Special torx drive tool.
You forgot to explain how to remove the two silver end caps one of them has a philips head screw that has to be removed from the inside,
and it’s hard to find because it’s usually full of lint.
On model NV 752 the torx screw is a T20, not T25. and it is the screw that is in the middle of the unit, not on the end where the red circle is shown above. This is not for the feint of heart. I have now replaced the roller and I am having trouble putting it back together again.
I have replaced roller brushes on other vacuums and this doesn’t have to be this difficult people. I love my Shark but may reconsider buying another based on how difficult it is to replace this roller brush.
I agree with you. The designer knew nothing about "design for assembly" and "design for servicing". I was a design engineer for over 30 years for generators. Those are two important aspects of design. Also, one tries to minimize the number of screws and attempts to make then all the same size. Anyone attempting this for the first time will rate this replacement as difficult. So why is a recessed torx bit required? Obviously, they want service reps to make money.
Tim Gurr -
My model number is UV770QCH but it's similar to NV 750 W. I too had a Phillips screw hidden on the belt side under the brush. There was a Phillips screw that ran horizontal to the brush roll cassette that was very difficult to find. As others noted, it was located in a different position from the one pictured in this demo. Also, it was covered in lint and very awkward to reach (glad to have small hands for once). Most other screws required a Torx 20. Four screws (including hidden under brush screw) needed a 2.0 50ml Phillips. Hopefully, my new brush roller lasts a while.
Remove white cap with a Flathead screwdriver or any other wedge-like tool.
You forgot to remove the two end caps by prying them off with a flat head screw driver, the one on the motor drive end has a hidden
philips head screw that has to be removed from the inside before prying off, I know from experience
12 andere personen hebben deze handleiding voltooid.
19 opmerkingen
Same. Need a new brush bar.
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
Does anyone get a reply?
This would be extremely helpful if it also identified the replacement part and where to find it. I’ve been searching for an NV752 replacement brushroll for a month.
I have a NV751. Where do you get a replacement brush roll for it?
I see so many people on here needing a new brush roll for the Navigator, myself included. After looking online for MONTHS without any resolution, I can only assume they don't sell just the brush roll and want you to but the $130 motorized floor nozzle that includes the brush roll just to make money. What a joke! Spend big money on a very good vacuum, but Shark doesn't sell a simple (and common) replacement part? That's just crap! I tried calling their support number, but never got connected to an actual person - ever! Better off buying a Dyson, I guess…
This has been a bit of a frustration for me as well. I did contact Shark Customer Service, and they will give a discount as a “courtesy” for this mess they have created with this great series of vacuums. They billed me $51 for the floor assembly. The Uv795 is such a great vacuum and once you get a hold of Shark they are pretty darn good in taking care of existing customers. My vacuum works fine, just needs a new brush roller. This way, I pay $30 more than the cost of a part that does not exist (according to Shark), and the vacuum is good to go for a long time to come. Good luck to all.
I am Cameron Ngai, a contributor to this article. This page was part of an assignment for our technical writing class at Cal Poly, so we do not know anything beyond what we figured out to write this page. I only just revisited this page after being reminded by an I-fixit email and noticed this thread. I apologize for not being able to help any further and wish you luck in your endeavors.
My wife ordered one from Walmart, but they sent the one for the Navigator which did not fit! We had to order the entire Brush head assembly
from Shark.com
I have a Shark NV682, which I understand is same as NV680 and NV681. I’ve been searching for a brush replacement as well, finally found this video and after reading these comments I think the answer is YOU CAN’T! I’m not a youtube guy but someone should save the rest of the world aggravation and post “If you have THIS Model XXX” Shark Vacuum your only option is to buy the entire head power unit. Or, if there is a work around (another brush will work) that would be great to know as well.
The worst vaccum iv ever haf less than 12 month old when problems started, split hose ,now smell of burning ( electrical ) only average when it does work. Fortunatley I didnt discard my 12 years old Dyson rollerball ,and its far superior to the Shark liftaway.
NOT IMPRESSED IN THE SLIGHTEST.
I need a new rotatory brush for my NV752-31 Shark Rotator True Per Professional. Can you give me a link to where I can order one?
I purchased a replacement brush roll on Amazon (see info below). The replacement was a little tricky as screw locations and types varied from this demo. Make sure to read comments others have added to each step. My vacuum with the new brush roll works great. Good luck!
Description: Tivcroxs Replacement Brush Roll Compatible for Shark Rotator Powered Lift-Away NV750 NV752 NV650 NV650W NV750AND NV652 NV652C NV750W NV752BRN NV753C NV651 NV750W NV753 Vacuums
I couldn't find replacement for my uv770 qhc either. I've ordered a nv750 replacement bar from amazon. I'll post again if it works. As someone posted earlier, I think shark prefers that you order new floor motor including roll for $150 instead of spending $20 on just the new roll.
Update: I successfully replaced the brush roll on model number UV770QCH similar to NV 750 W.
I purchased a replacement brush roll on Amazon.
Link: https://www.amazon.com/dp/B0B3RV4YRF?psc...
Make certain to read blue comments in each step of this guide as screw locations and types can vary.
Mine had a Phillips screw that ran horizontal to the brush roll cassette that was very difficult to find. As others noted, it was located in a different position from the one pictured in this demo. Also, it was covered in lint (hard to see) and very awkward to reach (small hands helped). Most other screws required a Torx 20. Four screws (including hidden, horizontal screw) needed a 2.0 50 ml Phillips. Hope my new brush roller lasts a while as replacement was tricky - Good luck!
Thank you for this. Very helpful. I would never have found that horizontal screw.
