Ga door naar hoofdinhoud
Shark Rotator Powered Lift-Away Roller Brush Replacement
Wat je nodig hebt
  1. Shark Rotator Powered Lift-Away Roller Brush Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: stap 1, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Roller Brush Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: stap 1, afbeelding 2 van 2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 2, afbeelding 1 van 1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 3, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 3, afbeelding 2 van 2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 4, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 4, afbeelding 2 van 2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 5, afbeelding 1 van 1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 6, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 6, afbeelding 2 van 2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 7, afbeelding 1 van 1
    • Lift up the top cover now that all of the screws have been removed.
  8. Shark Rotator Powered Lift-Away Roller Brush Replacement, Roller Brush: stap 8, afbeelding 1 van 1
    • Remove white cap with a Flathead screwdriver or any other wedge-like tool.
  9. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 9, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 9, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 9, afbeelding 3 van 3
    • Gently push piece in.
    • Pull piece down and out of the container.
  10. Shark Rotator Powered Lift-Away Roller Brush Replacement: stap 10, afbeelding 1 van 1
    • Turn vacuum head over to remove brush.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Cameron Ngai
718 Reputatie
3 handleidingen geschreven
Cal Poly, Team S9-G3, Banghart Fall 2017 Lid van Cal Poly, Team S9-G3, Banghart Fall 2017
CPSU-BANGHART-F17S9G3
4 Leden
12 handleidingen geschreven
19 opmerkingen
Where do you get the rotator brush? All I can find are the two for the Navigator.
Dave - Antwoord
Same. Need a new brush bar.
Michael Brennan - Antwoord
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
Ah Sum Taeza - Antwoord
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
crazeeincc - Antwoord
Does anyone get a reply?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 143
Afgelopen 30 dagen: 610
Altijd: 46,832
