Ga door naar hoofdinhoud
Shark Rotator Lift-Away Speed Brushroll Replacement
Wat je nodig hebt
  1. Shark Rotator Lift-Away Speed Brushroll Replacement, Brushroll: stap 1, afbeelding 1 van 1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Replacement: stap 2, afbeelding 1 van 2 Shark Rotator Lift-Away Speed Brushroll Replacement: stap 2, afbeelding 2 van 2
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Replacement: stap 3, afbeelding 1 van 2 Shark Rotator Lift-Away Speed Brushroll Replacement: stap 3, afbeelding 2 van 2
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
Conclusie
Weston Mongomery
201 Reputatie
2 handleidingen geschreven
Cal Poly, Team S15-G7, Livingston Fall 2017 Lid van Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 1,833
