Ga door naar hoofdinhoud
Shark Rocket Powerhead AH401 Panel Screws Replacement
Wat je nodig hebt
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: stap 1, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: stap 1, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: stap 1, afbeelding 3 van 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: stap 2, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: stap 2, afbeelding 2 van 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: stap 3, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: stap 3, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: stap 3, afbeelding 3 van 3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: stap 4, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: stap 4, afbeelding 2 van 2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: stap 5, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: stap 5, afbeelding 2 van 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Conclusie
Toan Pham
269 Reputatie
3 handleidingen geschreven
Cal Poly, Team S19-G3, Livingston Winter 2018 Lid van Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 934
