Ga door naar hoofdinhoud
Shark Rocket Powerhead AH401 Motherboard Replacement
Wat je nodig hebt
  1. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: stap 1, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: stap 1, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: stap 1, afbeelding 3 van 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 2, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: stap 3, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: stap 3, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: stap 3, afbeelding 3 van 3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 4, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: stap 5, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: stap 5, afbeelding 2 van 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  6. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver.
    • Remove the airpath grille by gently lifting up and away from the motor compartment.
  7. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 8, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 8, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Lift and gently remove the hinge compartment covering the motherboard.
  9. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
  10. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 10, afbeelding 1 van 2 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Lift the motherboard out of its compartment.
  11. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 11, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 11, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Locate and remove these connections by pulling the plugs out of the sockets.
  12. Shark Rocket Powerhead AH401 Motherboard Replacement: stap 12, afbeelding 1 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 12, afbeelding 2 van 3 Shark Rocket Powerhead AH401 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Flip the motherboard over to reveal the wires underneath.
    • Locate and cut all the wires connected to the motherboard using cutting pliers.
Conclusie
Shobhit Dabral
913 Reputatie
6 handleidingen geschreven
Cal Poly, Team S19-G3, Livingston Winter 2018 Lid van Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 508
