Inleiding
Removing the water tank will require removing the front panel and opening the mop body. Once accessible though, replacement is quite simple. Before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug the mop and empty the water tank for your safety.
Wat je nodig hebt
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
Één andere persoon heeft deze handleiding voltooid.
