Ga door naar hoofdinhoud
Shark Pet Perfect II Front Belt Replacement
Wat je nodig hebt
  1. Shark Pet Perfect II Front Belt Replacement, Front Belt: stap 1, afbeelding 1 van 1
    • Remove the motorized brush from the dust cup by pulling it apart.
  2. Shark Pet Perfect II Front Belt Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
  3. Shark Pet Perfect II Front Belt Replacement: stap 3, afbeelding 1 van 2 Shark Pet Perfect II Front Belt Replacement: stap 3, afbeelding 2 van 2
    • Separate the motorized brush face plate by using a flat prying tool.
  4. Shark Pet Perfect II Front Belt Replacement: stap 4, afbeelding 1 van 3 Shark Pet Perfect II Front Belt Replacement: stap 4, afbeelding 2 van 3 Shark Pet Perfect II Front Belt Replacement: stap 4, afbeelding 3 van 3
    • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
    • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
Conclusie
Bijgevoegde documenten
Tanner Brown
459 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G5, Liner Summer 2017 Lid van UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Leden
8 handleidingen geschreven
Één opmerking
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
Aaron Woods - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 778
