Inleiding
This guide will walk you through how to replace the roller brush.
Wat je nodig hebt
Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
42 andere personen hebben deze handleiding voltooid.
35 opmerkingen
Very helpful and easy. Thank you.
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
