Ga door naar hoofdinhoud
Shark Navigator Lightweight Upright Motor Replacement
Wat je nodig hebt
  1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: stap 1, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: stap 1, afbeelding 2 van 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motor Replacement: stap 2, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 2, afbeelding 2 van 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motor Replacement: stap 3, afbeelding 1 van 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motor Replacement: stap 4, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 4, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 4, afbeelding 3 van 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motor Replacement: stap 5, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motor Replacement: stap 6, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motor Replacement: stap 7, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motor Replacement: stap 8, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 8, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 8, afbeelding 3 van 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motor Replacement, Motor: stap 9, afbeelding 1 van 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motor Replacement: stap 10, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 10, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 10, afbeelding 3 van 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motor Replacement: stap 11, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 11, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 11, afbeelding 3 van 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motor Replacement: stap 12, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 12, afbeelding 2 van 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Suzie
527 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G6, Livingston Fall 2017 Lid van Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Leden
12 handleidingen geschreven
2 opmerkingen
Where does one buy the replacement motor?
Michael De La Rosa - Antwoord
Where can I get spares??
ck
Clive Kingscote - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 50
Altijd: 9,524
