Ga door naar hoofdinhoud
Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: stap 1, afbeelding 1 van 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: stap 1, afbeelding 2 van 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: stap 1, afbeelding 3 van 3
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: stap 2, afbeelding 1 van 2 Shark Navigator Lightweight Upright Hose Replacement: stap 2, afbeelding 2 van 2
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: stap 3, afbeelding 1 van 3 Shark Navigator Lightweight Upright Hose Replacement: stap 3, afbeelding 2 van 3 Shark Navigator Lightweight Upright Hose Replacement: stap 3, afbeelding 3 van 3
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kahye Yu
446 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G6, Livingston Fall 2017 Lid van Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Leden
12 handleidingen geschreven
3 opmerkingen
Where can I find a replacement hose?
Vance Payne - Antwoord
How to replace the bottom pick up hose.
rgg20319 - Antwoord
How to fix the bottom hose?
rgg20319 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 70
Altijd: 3,335
