Ga door naar hoofdinhoud
Shark Navigator Lightweight Upright Dust Cup Replacement
  1. Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: stap 1, afbeelding 1 van 2 Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: stap 1, afbeelding 2 van 2
    • Press down on the black, rubber ballish button located on the top of the vacuum.
    • Pull back simultaneous on the plastic handle and remove the dust container.
  2. Shark Navigator Lightweight Upright Dust Cup Replacement: stap 2, afbeelding 1 van 3 Shark Navigator Lightweight Upright Dust Cup Replacement: stap 2, afbeelding 2 van 3 Shark Navigator Lightweight Upright Dust Cup Replacement: stap 2, afbeelding 3 van 3
    • Press the plastic tab in, located on the front of the dust container.
    • Pull up simultaneously on the plastic handle.
  3. Shark Navigator Lightweight Upright Dust Cup Replacement: stap 3, afbeelding 1 van 2 Shark Navigator Lightweight Upright Dust Cup Replacement: stap 3, afbeelding 2 van 2
    • Remove the dust cup from the inside of the dust container.
  4. Shark Navigator Lightweight Upright Dust Cup Replacement: stap 4, afbeelding 1 van 3 Shark Navigator Lightweight Upright Dust Cup Replacement: stap 4, afbeelding 2 van 3 Shark Navigator Lightweight Upright Dust Cup Replacement: stap 4, afbeelding 3 van 3
    • Push in the red tab located on the side of the dust cup.
    • Open the dust cup simultaneously with the cone-half pointing downwards.
    • Separate the two halves.
Conclusie
Kahye Yu
446 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G6, Livingston Fall 2017 Lid van Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 91
Altijd: 3,319
