Ga door naar hoofdinhoud
Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement
Wat je nodig hebt
  1. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: stap 1, afbeelding 1 van 2 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: stap 1, afbeelding 2 van 2
    • Make sure to turn off the vacuum and unplug it from the outlet.
  2. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: stap 2, afbeelding 1 van 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: stap 2, afbeelding 2 van 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: stap 2, afbeelding 3 van 3
    • Push down on the bottom of the vacuum so it can dangle.
    • Using a flathead screwdriver to turn the lock counterclockwise, then open the cover to access the brush roll.
  3. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: stap 3, afbeelding 1 van 1
    • Clear out any debris and close up the bottom using the previous steps.
    • Unfortunately, the new technology implemented in the self-cleaning brush roll prevents it from being detachable. You have a guaranteed 5-year warranty from Shark. Contact them using this link.
Conclusie
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
Bijgevoegde documenten
Nadir Abdusemed
124 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 11-5, Grodsky Fall 2021 Lid van CSU Los Angeles, Team 11-5, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G5
1 Lid
1 handleiding geschreven
Één opmerking
The brush roller and placement of it is filthy with dog hair and dirt needs to be scraped out. There must be a way to remove it to clean without having to send it to the manufacturer
Nana - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 129
Altijd: 4,182
