Ga door naar hoofdinhoud
Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement
Wat je nodig hebt
  1. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement, Roller Brush Belt: stap 1, afbeelding 1 van 2 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement, Roller Brush Belt: stap 1, afbeelding 2 van 2
    • Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
  2. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 2, afbeelding 1 van 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 2, afbeelding 2 van 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 2, afbeelding 3 van 3
    • Insert the metal spudger between the inside side of the wheel and the plastic body.
    • Push the metal spudger away from you to pop the wheels out.
    • Repeat the step to remove the other wheel on the other side.
  3. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 3, afbeelding 1 van 1
    • Remove the six 15mm screws using the PH1 screwdriver.
  4. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 4, afbeelding 1 van 2 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 4, afbeelding 2 van 2
    • Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
  5. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 5, afbeelding 1 van 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 5, afbeelding 2 van 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
    • Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
  6. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 6, afbeelding 1 van 2 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 6, afbeelding 2 van 2
    • Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
  7. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 7, afbeelding 1 van 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 7, afbeelding 2 van 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 7, afbeelding 3 van 3
    • Lift the roller brush slightly upwards using your hand.
    • Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
  8. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: stap 8, afbeelding 1 van 1
    • Remove the roller brush belt with your hands by sliding it of the end of the motor.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Elena Postupalskaya
1.159 Reputatie
6 handleidingen geschreven
Cal Poly, Team S15-G2, Livingston Fall 2017 Lid van Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Leden
14 handleidingen geschreven
8 opmerkingen
Whhhhyyyyyy does this require a special, hard to find bit to disassemble!!!!! I have screw driver set with everything from philips, standard, Allen and even the star bits. But they had to go a use one with a %#*@ peg in the middle rendering all my tools useless. Had I known I would never have bought it.
Forrest Sutton - Antwoord
I agree, Yeah why!
Ellen Long -
You can by a tamper proof hex set for like $7 on Amazon.
Bryan Hawkins - Antwoord
My roller brush is just locked. I have the hair cleaned out but it won’t budge. Is there a release button somewhere?
Amy Johnson - Antwoord
I need to know the same thing please
April McClure -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 399
Altijd: 36,305
