Ga door naar hoofdinhoud
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: stap 1, afbeelding 1 van 1
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 2, afbeelding 1 van 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 2, afbeelding 2 van 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 2, afbeelding 3 van 3
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 3, afbeelding 1 van 2 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 3, afbeelding 2 van 2
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 4, afbeelding 1 van 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 4, afbeelding 2 van 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 4, afbeelding 3 van 3
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 5, afbeelding 1 van 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 5, afbeelding 2 van 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: stap 5, afbeelding 3 van 3
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
Conclusie
Pramika Kumar
258 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G2, Livingston Fall 2017 Lid van Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 54
Altijd: 5,055
