Inleiding
When the roller belt has snapped or your vacuum's roller brush is not spinning, you should look into replacing your roller belt.
Wat je nodig hebt
Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum.
Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
4 andere personen hebben deze handleiding voltooid.
20 opmerkingen
Where can I purchase the belt. It is a “Pioneer Rubber Belt 148 2m”.
Please contact me.
Thank you.
itsagas03@hotmail.com
Try amazon…replacement belt for shark navigator freestyle cordless vacuum
I got the belt from http://shop.polybelt.com/ It is item B148-2M-04BNG . You have to buy 3 to get to $9.99 and then they tack on another $10 for shipping, but this was the only place I could find them. Replaced it and it seems to be working ok.
The brush stops tolling after a few seconds. How do I trouble shoot this?
Same happens to me. I took it all apart; there was not much hair in the mechanisms at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next.
