Ga door naar hoofdinhoud
Shark Navigator Freestyle SV1106 Battery Pack Replacement
Wat je nodig hebt
  1. Shark Navigator Freestyle SV1106 Battery Pack Replacement, Battery Pack: stap 1, afbeelding 1 van 1
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 2, afbeelding 1 van 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 2, afbeelding 2 van 2
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 3, afbeelding 1 van 1
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 4, afbeelding 1 van 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 4, afbeelding 2 van 2
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 5, afbeelding 1 van 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Zachary Liu
604 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G5, Livingston Winter 2018 Lid van Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Leden
10 handleidingen geschreven
8 opmerkingen
How much is the part for the shark
sumi49 - Antwoord
My Shark SV1106 doesn’t stay on very long. One episode you turn it on it immediately turns off. So what is the issue?
jklab23 - Antwoord
How much is a battery pack?
ridgeite145 - Antwoord
Items OrderedPrice1 of: 10.8V 3000mah Battery for Shark XBT1106N SV1110 SV1106N SV1110N SV11O6N SV116N Freestyle Navigator Cordless Stick Vacuum
Sold by: Areotek Direct (seller profile)
Condition: New
James Mayoral -
How much is a new battery pack for replacement
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 62
Altijd: 10,777
