Ga door naar hoofdinhoud
Shark NV352 Roller Brush Replacement
Wat je nodig hebt
  1. Shark NV352 Roller Brush Replacement, Roller Brush: stap 1, afbeelding 1 van 2 Shark NV352 Roller Brush Replacement, Roller Brush: stap 1, afbeelding 2 van 2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Replacement: stap 2, afbeelding 1 van 1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Replacement: stap 3, afbeelding 1 van 2 Shark NV352 Roller Brush Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Replacement: stap 4, afbeelding 1 van 2 Shark NV352 Roller Brush Replacement: stap 4, afbeelding 2 van 2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Replacement: stap 5, afbeelding 1 van 2 Shark NV352 Roller Brush Replacement: stap 5, afbeelding 2 van 2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Replacement: stap 6, afbeelding 1 van 2 Shark NV352 Roller Brush Replacement: stap 6, afbeelding 2 van 2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Replacement: stap 7, afbeelding 1 van 1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Replacement: stap 8, afbeelding 1 van 1
    • Take out the roller brush by lifting it out of its tray.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Amy Moran
603 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G5, Forte Fall 2017 Lid van Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Leden
10 handleidingen geschreven
1Gids Commentaar
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
elaina heinz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 66
Altijd: 5,300
