Inleiding
If your Shark ION Robot S87 has problems getting around, then you may need some new drive wheels. This guide will show you how to replace the wheels, and get it cleaning again.
Wat je nodig hebt
Remove three 13mm screws using a T15 Torx screwdriver.
Remove one 15mm screw using a Phillips #1 screwdriver.
Remove one final 15mm Phillips #1 screw.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
