Inleiding
Your Shark ION Robot S87 may have a blocked suction motor, or the robot may be running into objects while in use. This problem may have to do with the bumper of the robot and whether or not it is assembled accurately. Items and/or other debris may be stuck in front of the sensors causing the robot to bump into objects. This replacement guide will teach you how to fix these common problems.
Wat je nodig hebt
Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
