Ga door naar hoofdinhoud
Shark ION Robot S87 Bumper Replacement
Wat je nodig hebt
  1. Shark ION Robot S87 Bumper Replacement, Bumper: stap 1, afbeelding 1 van 1
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: stap 2, afbeelding 1 van 3 Shark ION Robot S87 Bumper Replacement: stap 2, afbeelding 2 van 3 Shark ION Robot S87 Bumper Replacement: stap 2, afbeelding 3 van 3
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: stap 3, afbeelding 1 van 1
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
Conclusie
Adeel Ahmad
256 Reputatie
2 handleidingen geschreven
Één opmerking
Where can I buy a new bumper?
Lacy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 154
Altijd: 11,746
