Ga door naar hoofdinhoud
Shark ION Robot R75 Side Brush Replacement
Wat je nodig hebt
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: stap 1, afbeelding 1 van 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: stap 1, afbeelding 2 van 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: stap 1, afbeelding 3 van 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
Conclusie
2 opmerkingen
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - Antwoord
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 146
Altijd: 6,088
