Ga door naar hoofdinhoud
Shark ION Robot R75 Caster Wheel Replacement
Wat je nodig hebt
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: stap 1, afbeelding 1 van 1
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: stap 2, afbeelding 1 van 3 Shark ION Robot R75 Caster Wheel Replacement: stap 2, afbeelding 2 van 3 Shark ION Robot R75 Caster Wheel Replacement: stap 2, afbeelding 3 van 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: stap 3, afbeelding 1 van 3 Shark ION Robot R75 Caster Wheel Replacement: stap 3, afbeelding 2 van 3 Shark ION Robot R75 Caster Wheel Replacement: stap 3, afbeelding 3 van 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
Conclusie
Één opmerking
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 58
Altijd: 4,875
