Ga door naar hoofdinhoud
Shark ION Robot 750 Battery Replacement
Wat je nodig hebt
  1. Shark ION Robot 750 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: stap 2, afbeelding 1 van 2 Shark ION Robot 750 Battery Replacement: stap 2, afbeelding 2 van 2
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: stap 3, afbeelding 1 van 2 Shark ION Robot 750 Battery Replacement: stap 3, afbeelding 2 van 2
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
Eindstreep
Tuong Tran
196 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 121
