Inleiding
This repair may be necessary if the brush roll is not spinning. The belt is tight on the roll and may require some force to remove it.
Wat je nodig hebt
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Remove old the belt from the two gears by prying it off using the metal spudger.
9 andere personen hebben deze handleiding voltooid.
10 opmerkingen
Where to get the carpet brush belt? What would the belt size be?
Add me to the rest. I also want a belt. Does anybody ever respond to these questions?
I’m hopeful we can find a source
ShellyB
shellyb -
the belt, roller brush, entire floor unit, etc are on amazon
