Ga door naar hoofdinhoud
Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement
Wat je nodig hebt
  1. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement, Brushroll: stap 1, afbeelding 1 van 3 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement, Brushroll: stap 1, afbeelding 2 van 3 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement, Brushroll: stap 1, afbeelding 3 van 3
    • Press the two Brush Roll Access buttons down at the same time to detach the cover.
    • Pull the cover off of the vacuum by lifting it up.
  2. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 2, afbeelding 1 van 2 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 2, afbeelding 2 van 2
    • Pull up on the Pull Tab to remove the large brush roll.
  3. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 3, afbeelding 1 van 2 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 3, afbeelding 2 van 2
    • Press the Eject Roller button to detach the small roller.
    • Pull the roller away from the vacuum to remove it.
  4. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement, Drive Belt: stap 4, afbeelding 1 van 2 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement, Drive Belt: stap 4, afbeelding 2 van 2
    • Use the T20 screwdriver to remove the four 17 mm screws by turning counterclockwise.
  5. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 5, afbeelding 1 van 2 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 5, afbeelding 2 van 2
    • Use the T20 screwdriver to remove the six 19 mm screws by turning counterclockwise.
    • Use the T20 screwdriver to remove the one 12 mm screw by turning counterclockwise.
    • Use the T10 screwdriver to remove the four 14 mm screws by turning counterclockwise.
  6. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 6, afbeelding 1 van 3 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 6, afbeelding 2 van 3 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 6, afbeelding 3 van 3
    • Use the spudger tool to pry off the red plastic corner cap.
    • Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time.
  7. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 7, afbeelding 1 van 1
    • Remove the red cover by lifting upward.
  8. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 8, afbeelding 1 van 1
    • Remove the light fixture by lifting it up.
  9. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 9, afbeelding 1 van 2 Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 9, afbeelding 2 van 2
    • Use the spudger to detach the orange drive belt compartment from the vacuum.
    • Remove the orange drive belt compartment from the vacuum by lifting it upwards.
  10. Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement: stap 10, afbeelding 1 van 1
    • Pull outward on the smaller drive belt to remove it.
    • Pull outward on the larger drive belt to remove it.
    • The smaller drive belt must be removed first in order to remove the second larger belt.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Catie Halvorsen
703 Reputatie
5 handleidingen geschreven
Cal Poly, Team S17-G4, White Fall 2018 Lid van Cal Poly, Team S17-G4, White Fall 2018
CPSU-WHITE-F18S17G4
4 Leden
16 handleidingen geschreven
38 opmerkingen
What a pain in the ***! The star bit wouldn't fit on one of the screws and had to use a small reg. screwdriver to get it out. This is a very poor design. I've only used the sweeper a few times too. Hope the belts don't come off or break often because if they do it's going in the dumpster and never buying another one. Do not recommend this sweeper!!! Very disappointed.
Deann Shumaker - Antwoord
The spudger saved the day.
Excellent guide. You saved me hours of frustration
Callum - Antwoord
What size belt I need for this vacuum
Melissa Beaver - Antwoord
Very bad design will stick to our dyson will not recommend it go any one
satmansteve00 - Antwoord
It’s really not bad. This vacuum has out performed and lived many Dysons. I’ll never go back! They are half the price and accept coupons too
ryannmacintosh -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 316
Altijd: 68,898
