Inleiding
If you are having a problem with your device's Front motor, Here is a Step by step guide to replace a faulty or broken Front motor.
Wat je nodig hebt
Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
Remove the belt from the motor mount, and then replace with a new belt.
Do you guys have a guide on replacing the smaller white rolling piece that is part of the motor mount? This is the reason why the brush roller doesn’t spin on my shark cordless vacuum. The piece itself is too small to fit on the motor or maybe the motor’s too big for that piece. I’m seriously getting to the point that I want to just toss this piece in the trash. Any help would be greatly appreciated.
Remove the solder from both motor terminals.
Where do I order a new belt for my handheld cordless vacumn
Where can I purchase a new belt for my handheld Shark cordless vacumn. I guess it is model number. 3037613. I bought it at Walmart a few years back. I appreciate your help.
3 andere personen hebben deze handleiding voltooid.
