Ga door naar hoofdinhoud
Shark Clean Sense HP102PET Shell Replacement
Wat je nodig hebt
  1. Shark Clean Sense HP102PET Shell Replacement, Outer White Shell: stap 1, afbeelding 1 van 3 Shark Clean Sense HP102PET Shell Replacement, Outer White Shell: stap 1, afbeelding 2 van 3 Shark Clean Sense HP102PET Shell Replacement, Outer White Shell: stap 1, afbeelding 3 van 3
    • Turn off and unplug the air purifier before beginning.
    • Unscrew the one 1.2 cm screw holding the grate at the top with a TR10 Torx screwdriver.
    • Use a prying tool to carefully pry along the outer edges to disengage the inner retaining clips.
    • These retaining clips can be difficult to disengage, but releasing two clips on the same side should allow you to easily remove the grate.
    • Remove the grate.
  2. Shark Clean Sense HP102PET Shell Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 1.2 cm screws with a TR10 Torx screwdriver.
    • Almost all screws are the same length (around 1 cm). The main difference is the bit that's used to remove them.
  3. Shark Clean Sense HP102PET Shell Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the four 1 cm screws.
    • This will make the fan holder slightly loose, but this will not be a problem until you open the case completely.
  4. Shark Clean Sense HP102PET Shell Replacement: stap 4, afbeelding 1 van 3 Shark Clean Sense HP102PET Shell Replacement: stap 4, afbeelding 2 van 3 Shark Clean Sense HP102PET Shell Replacement: stap 4, afbeelding 3 van 3
    • Flip the device over and unscrew the bottom by turning it clockwise.
    • Remove the filter.
  5. Shark Clean Sense HP102PET Shell Replacement: stap 5, afbeelding 1 van 2 Shark Clean Sense HP102PET Shell Replacement: stap 5, afbeelding 2 van 2
    • Remove the five 1 cm a Phillips screwdriver.
    • Unscrew the four 1.2 cm screws with a TR10 Torx screwdriver.
    • The ring will not be hard to remove, but be careful on reassembly. Make sure that the power connector is properly seated when putting the ring back on.
    I just took my model apart (purchased in 2023) and for this step mine only had T10 1.2cm screws on the shell seams (I have 5 total — 4 for the seams and 1 that holds down the top grate). The rest of mine are Phillips 1cm screws. Just in case anyone with my model follows these steps to put everything back together!
    Maddie D - Antwoord
  6. Shark Clean Sense HP102PET Shell Replacement: stap 6, afbeelding 1 van 2 Shark Clean Sense HP102PET Shell Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 1 cm screws that secure the fan housing.
  7. Shark Clean Sense HP102PET Shell Replacement: stap 7, afbeelding 1 van 3 Shark Clean Sense HP102PET Shell Replacement: stap 7, afbeelding 2 van 3 Shark Clean Sense HP102PET Shell Replacement: stap 7, afbeelding 3 van 3
    • Make sure that you are pulling up on the side that allows, as pictured in the red box.
    • Gently slide the cases up and down, or hold one and gently pull up on the opposite side (Down on the left, up on the right for this picture).
    • The whole case will start to separate and the black disc will come loose. This is normal.
  8. Shark Clean Sense HP102PET Shell Replacement: stap 8, afbeelding 1 van 3 Shark Clean Sense HP102PET Shell Replacement: stap 8, afbeelding 2 van 3 Shark Clean Sense HP102PET Shell Replacement: stap 8, afbeelding 3 van 3
    • Gently open the case outwards as there are fragile electronics inside.
    • Remove the fan housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
KyreseAguilar
727 Reputatie
5 handleidingen geschreven
1Gids Commentaar
Thank you for this! My air purifier was making noise and I couldn’t find any guides to take it apart. This helped me clean it out and get rid of the noise! :-)
Maddie D - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 31
Altijd: 116
