Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Examine the damage. Clip any loose threads and remove any debris from the tear.
Grab a trendy patch.
Position the patch over the hole.
Any patch you use should overlap the damage by at least 1/8".
Slide the jeans into the sewing machine, positioning the needle over the edge of the patch.
Lower the pressor foot.
Sew along the edge of the patch.
Remove the pins before you get to them.
Continue sewing around the patch, lifting the pressor foot to turn at corners of the patch.
When you come all the way around, overlap the first two or three stitches.
Lift the needle and pressor foot.
Slide the jeans out of the sewing machine.
Clip any threads, and admire your work.
4 andere personen hebben deze handleiding voltooid.
