Ga door naar hoofdinhoud
Seville Classics MSC10166 Buttons Replacement
Wat je nodig hebt
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): stap 1, afbeelding 1 van 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Buttons Replacement: stap 2, afbeelding 1 van 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Buttons Replacement: stap 3, afbeelding 1 van 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Buttons Replacement: stap 4, afbeelding 1 van 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Buttons Replacement: stap 5, afbeelding 1 van 2 Seville Classics MSC10166 Buttons Replacement: stap 5, afbeelding 2 van 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: stap 6, afbeelding 1 van 1
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
  7. Seville Classics MSC10166 Buttons Replacement: stap 7, afbeelding 1 van 1
    • Remove the buttons from the top cover.
  8. Seville Classics MSC10166 Buttons Replacement: stap 8, afbeelding 1 van 1
    • Wipe down any dirt on the buttons.
  9. Seville Classics MSC10166 Buttons Replacement: stap 9, afbeelding 1 van 1
    • Wipe down the frame that holds the buttons.
Conclusie
Queena Phung
114 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-46, Forte Fall 2012 Lid van Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Leden
6 handleidingen geschreven
2 opmerkingen
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Antwoord
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 3,936
