Ga door naar hoofdinhoud
Service door disassembly
Wat je nodig hebt
  1. Service door disassembly, Remove the battery: stap 1, afbeelding 1 van 3 Service door disassembly, Remove the battery: stap 1, afbeelding 2 van 3 Service door disassembly, Remove the battery: stap 1, afbeelding 3 van 3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
  2. Service door disassembly, Remove the captive screw of the service door: stap 2, afbeelding 1 van 1
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
  3. Service door disassembly, Remove the service door: stap 3, afbeelding 1 van 3 Service door disassembly, Remove the service door: stap 3, afbeelding 2 van 3 Service door disassembly, Remove the service door: stap 3, afbeelding 3 van 3
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
  4. Service door disassembly, Identify the components: stap 4, afbeelding 1 van 1
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
Conclusie
Roberto Bartolacci
1.548 Reputatie
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 408
