Ga door naar hoofdinhoud
Sennheiser RS120 Battery Replacement
Wat je nodig hebt
  1. Sennheiser RS120 Battery Replacement, Ear Pad: stap 1, afbeelding 1 van 3 Sennheiser RS120 Battery Replacement, Ear Pad: stap 1, afbeelding 2 van 3 Sennheiser RS120 Battery Replacement, Ear Pad: stap 1, afbeelding 3 van 3
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
  2. Sennheiser RS120 Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Sennheiser RS120 Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Gayle Dunham
375 Reputatie
1 Handleiding geschreven
7 opmerkingen
Thanks for the information - this made changing the batteries a snap.
Jim K - Antwoord
Extremely helpful. Thank you!
-Randy N
Randy - Antwoord
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - Antwoord
Thanks! You solved my mystery.
Marilyn Carini - Antwoord
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 142
Altijd: 44,857
