Ga door naar hoofdinhoud
Sennheiser HD 4.50 Motherboard Replacement
Wat je nodig hebt
  1. Sennheiser HD 4.50 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Locate the side designation on the headband-earpiece junction.
    • The motherboard is located on the right side.
    • Remove the right side ear pad.
    • Refer to the Ear Pad Removal guide for more guidance.
  2. Sennheiser HD 4.50 Motherboard Replacement: stap 2, afbeelding 1 van 3 Sennheiser HD 4.50 Motherboard Replacement: stap 2, afbeelding 2 van 3 Sennheiser HD 4.50 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry off the cover.
  3. Sennheiser HD 4.50 Motherboard Replacement: stap 3, afbeelding 1 van 3 Sennheiser HD 4.50 Motherboard Replacement: stap 3, afbeelding 2 van 3 Sennheiser HD 4.50 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
  4. Sennheiser HD 4.50 Motherboard Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the hot glue that covers the wires
    • Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
  5. Sennheiser HD 4.50 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Use the iFixit opening tools to lift up on the motherboard.
    • While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
    • There may be some resistance in this step.
  6. Sennheiser HD 4.50 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Desolder the three wires that are on the underside of the motherboard now that it is free.
    • Remove the motherboard.
Conclusie
Grace Singley
595 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 129
Altijd: 2,443
