Ga door naar hoofdinhoud
Seiko Strap Adjustment
  1. Seiko Strap Adjustment, Strap Links: stap 1, afbeelding 1 van 1
    • Note the arrow direction on each link.
    • Note the orientation of each pin upon removal.
  2. Seiko Strap Adjustment: stap 2, afbeelding 1 van 2 Seiko Strap Adjustment: stap 2, afbeelding 2 van 2
    • Push pins out in the direction of link arrows.
    • Use either a strong tweezer or P2 bit.
    • avoid scratching by putting an old T-shirt down on your work surface.
    • expect to push hard. Pins go out in the direction of the arrow on the link.
  3. Seiko Strap Adjustment: stap 3, afbeelding 1 van 2 Seiko Strap Adjustment: stap 3, afbeelding 2 van 2
    • Pull pins out slowly.
    • Note the orientation of each pin.
    • Expect the watch to fall apart.
  4. Seiko Strap Adjustment: stap 4, afbeelding 1 van 1
    • Push pins opposite direction of link arrows to insert.
    • This may require a lot of force.
    • Brace your workspace and use soft linens to avoid scratches.
  5. Seiko Strap Adjustment: stap 5, afbeelding 1 van 1
    • Remove and replace as many links as needed to adjust strap length.
    • Mark this guide complete to help others find it
Conclusie
5 andere personen hebben deze handleiding voltooid.
Dean Gadberry
508 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 66
Altijd: 918
