Ga door naar hoofdinhoud
Sega Master System Model 2 Disassembly
Wat je nodig hebt
Video overzicht
  1. Sega Master System Model 2 Disassembly, The Case: stap 1, afbeelding 1 van 1
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: stap 2, afbeelding 1 van 1
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: stap 3, afbeelding 1 van 1
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: stap 4, afbeelding 1 van 1
    • Congratulations! You have opened your Sega Master System Model 2!
Conclusie
Screenshots taken from a video by Global Garage
3 andere personen hebben deze handleiding voltooid.
Krisander 1998
641 Reputatie
2 handleidingen geschreven
3Gids Commentaar
This is in the wrong section.
Owen Ready - Antwoord
Nope, its in the Sega Master System area.
Krisander 1998 -
Not a Master System
Chad Luciano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 40
Altijd: 3,216
