Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four outer screws (you may want a small cup to keep your screws in.)
You now have access to your circuit board. (If you wish to remove the circuit board, continue.)
Remove the two screws highlighted in picture to remove the circuit board.
You now have access to the inside of the bottom plastic piece.
