Ga door naar hoofdinhoud
Sega Game Gear TV Tuner Disassembly
Wat je nodig hebt
  1. Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: stap 1, afbeelding 1 van 2 Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: stap 1, afbeelding 2 van 2
    • Remove PH1 screw and lift up on the antenna to remove it
    • This can be done with a PH0 screwdriver but I prefer not to risk stripping the screw
    • Remove 4 PH0 screws
    • Remove 2 3.8mm gamebit screws
    • Lift rear tuner shell away from unit
  2. Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: stap 2, afbeelding 1 van 3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: stap 2, afbeelding 2 van 3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: stap 2, afbeelding 3 van 3
    • Before we can remove the motherboard the tint wheel needs to be removed
    • A peek on the inside reveals 2 small retaining clips. Simply apply some pressure on the clips with a needle nose tweezer
    • When reinstalling the tint wheel simply align the retaining clips with the holes and press back into place
    • Remove the motherboard from the unit
  3. Sega Game Gear TV Tuner Disassembly, Remove PCBs: stap 3, afbeelding 1 van 2 Sega Game Gear TV Tuner Disassembly, Remove PCBs: stap 3, afbeelding 2 van 2
    • When removing the front shell be careful not to lose the frequency switch button located on top of the device
    • If it makes your repair easier you can separate the two PCBs by gently pulling the ribbon out of its connector. This is a friction fit cable
  4. Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: stap 4, afbeelding 1 van 3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: stap 4, afbeelding 2 van 3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: stap 4, afbeelding 3 van 3
    • Flip the PCBs over with the back side facing you.
    • Remove 1 PH0 screw
    • Flip the board over again and gently pull the tuning dial assembly out of the pin header socket
Conclusie
Navy Vet 2015
7.296 Reputatie
15 handleidingen geschreven
3 opmerkingen
does anybody know what the ribbon cables pinout is? I would love to know, so I can hook up some video-in to the tv tuner board, since my good guess is, that the upper part is just transporting or converting the signal it gets from its receiver to a mere video-in signal with LandR audio, since you can also hook up video-in to the tv tuner on the jack. and my other wild guess is, that the board the actual receiver is hooked up to splits up the signal into 8-bit chunks the game gear itself can understand. Please feel free to correct me and give more info, i NEED the pinout, since i got no tools at home to check what the ribbon cable actually is cooking.
patoschkapeter - Antwoord
A small washer fell out of mine when I was taking it apart. Any idea where it goes?
Kyle Mitchell - Antwoord
If it's very thin and small circumference it goes between the antenna and swivel. There may be 2 of them.
Navy Vet 2015 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 56
Altijd: 3,116
