Ga door naar hoofdinhoud
Sega Game Gear Speakers Replacement
Wat je nodig hebt
Video overzicht
  1. Sega Game Gear Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Speakers Replacement: stap 2, afbeelding 1 van 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Speakers Replacement, Case: stap 3, afbeelding 1 van 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Speakers Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Speakers Replacement: stap 5, afbeelding 1 van 2 Sega Game Gear Speakers Replacement: stap 5, afbeelding 2 van 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Speakers Replacement: stap 6, afbeelding 1 van 3 Sega Game Gear Speakers Replacement: stap 6, afbeelding 2 van 3 Sega Game Gear Speakers Replacement: stap 6, afbeelding 3 van 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Speakers Replacement, Speakers: stap 7, afbeelding 1 van 1
    • Unscrew the 8 Phillips screws from the logic board.
  8. Sega Game Gear Speakers Replacement: stap 8, afbeelding 1 van 1
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  9. Sega Game Gear Speakers Replacement: stap 9, afbeelding 1 van 2 Sega Game Gear Speakers Replacement: stap 9, afbeelding 2 van 2
    • Removing the plastic holding the speaker to the case may permanently detach the speaker.
    • The plastic at these three locations is melted to the plastic. Pry off with caution.
Conclusie
Lauren Thurston
469 Reputatie
3 handleidingen geschreven
Cal Poly, Team 28-33, Regan Spring 2010 Lid van Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Leden
13 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 43
Altijd: 12,278
