Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place your device upside down and locate the two battery compartments.
Press on the tabs at the bottom of the battery covers then lift up to remove.
Remove batteries if they are present.
Remove the following screws:
Six Phillips screws
One 4.5 mm Gamebit screw
Gently open the case by unfolding it over the top of the Sega Game Gear.
Carefully unplug the 2 white-tipped connectors on the top cover.
Slide the logic board out from under the circular black fastener at the top-left corner of the case.
8 andere personen hebben deze handleiding voltooid.
