Ga door naar hoofdinhoud
Sega Game Gear Headphone Jack/Volume Wheel Replacement
Wat je nodig hebt
  1. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 2, afbeelding 1 van 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Case: stap 3, afbeelding 1 van 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 4, afbeelding 1 van 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 5, afbeelding 1 van 2 Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 5, afbeelding 2 van 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 6, afbeelding 1 van 3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 6, afbeelding 2 van 3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 6, afbeelding 3 van 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: stap 7, afbeelding 1 van 2 Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: stap 7, afbeelding 2 van 2
    • Unscrew the screws to remove the metal covering.
  8. Sega Game Gear Headphone Jack/Volume Wheel Replacement: stap 8, afbeelding 1 van 1
    • The screws that need to be removed are missing from this picture.
    • Remove the two screws from the highlighted locations.
Conclusie
Brandon Page
182 Reputatie
2 handleidingen geschreven
Cal Poly, Team 28-33, Regan Spring 2010 Lid van Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 7,101
