Ga door naar hoofdinhoud
Sega Dreamcast Logic Board Replacement
Wat je nodig hebt
  1. Sega Dreamcast Logic Board Replacement, Expansion Bay: stap 1, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement, Expansion Bay: stap 1, afbeelding 2 van 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Logic Board Replacement: stap 2, afbeelding 1 van 3 Sega Dreamcast Logic Board Replacement: stap 2, afbeelding 2 van 3 Sega Dreamcast Logic Board Replacement: stap 2, afbeelding 3 van 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Logic Board Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Logic Board Replacement: stap 4, afbeelding 1 van 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): stap 5, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): stap 5, afbeelding 2 van 2
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Sega Dreamcast Logic Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Sega Dreamcast Logic Board Replacement: stap 7, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 7, afbeelding 2 van 2
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Sega Dreamcast Logic Board Replacement: stap 8, afbeelding 1 van 1
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
  9. Sega Dreamcast Logic Board Replacement, Controller Port: stap 9, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement, Controller Port: stap 9, afbeelding 2 van 2
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  10. Sega Dreamcast Logic Board Replacement: stap 10, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 10, afbeelding 2 van 2
    • Remove the four 14mm Philips #02 screws located on the controller board.
  11. Sega Dreamcast Logic Board Replacement: stap 11, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the white fan header from the controller port.
  12. Sega Dreamcast Logic Board Replacement: stap 12, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 12, afbeelding 2 van 2
    • Remove the controller board by lifting it up from the controller port.
  13. Sega Dreamcast Logic Board Replacement, GD-ROM: stap 13, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement, GD-ROM: stap 13, afbeelding 2 van 2
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  14. Sega Dreamcast Logic Board Replacement: stap 14, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 14, afbeelding 2 van 2
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  15. Sega Dreamcast Logic Board Replacement: stap 15, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 15, afbeelding 2 van 2
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  16. Sega Dreamcast Logic Board Replacement: stap 16, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 16, afbeelding 2 van 2
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  17. Sega Dreamcast Logic Board Replacement, Fan: stap 17, afbeelding 1 van 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  18. Sega Dreamcast Logic Board Replacement: stap 18, afbeelding 1 van 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  19. Sega Dreamcast Logic Board Replacement: stap 19, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 19, afbeelding 2 van 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  20. Sega Dreamcast Logic Board Replacement, Logic Board: stap 20, afbeelding 1 van 3 Sega Dreamcast Logic Board Replacement, Logic Board: stap 20, afbeelding 2 van 3 Sega Dreamcast Logic Board Replacement, Logic Board: stap 20, afbeelding 3 van 3
    • Remove the five 10mm Philips #02 screws from left side of the logic board cover.
    • Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
  21. Sega Dreamcast Logic Board Replacement: stap 21, afbeelding 1 van 3 Sega Dreamcast Logic Board Replacement: stap 21, afbeelding 2 van 3 Sega Dreamcast Logic Board Replacement: stap 21, afbeelding 3 van 3
    • Lift the metal cover from the console.
  22. Sega Dreamcast Logic Board Replacement: stap 22, afbeelding 1 van 2 Sega Dreamcast Logic Board Replacement: stap 22, afbeelding 2 van 2
    • Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object.
    • Remove the logic board and set the logic board on an anti-static surface.
Conclusie
21 andere personen hebben deze handleiding voltooid.
wkwong
517 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-1, Regan Fall 2009 Lid van Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Leden
21 handleidingen geschreven
Één opmerking
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
Nickolas Wilcox - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 199
Altijd: 23,051
