Inleiding
A guide to remove the GD-ROM from the Sega Dreamcast.
Problem with this guide: The photos incorrectly show the power supply has been removed.
Onderdelen
Geen onderdelen nodig.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Voeg opmerking toe
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Voeg opmerking toe
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Voeg opmerking toe
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Voeg opmerking toe
Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Voeg opmerking toe
Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Voeg opmerking toe
Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket. The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
  • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
Voeg opmerking toe
When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base. Remove the GD-ROM by gently lifting it from its base.
  • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
  • Remove the GD-ROM by gently lifting it from its base.
Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
wkwong
381 reputatie
13 handleidingen geschreven
Cal Poly, Team 5-1, Regan Fall 2009 Lid van Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Leden
23 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 14
Afgelopen 30 Dagen: 73
Altijd: 14,536
