Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Turn the console right side up.
Remove the top cover by gently lifting the upper portion of the console.
Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
Remove the GD-ROM by gently lifting it from its base.
Replace the bad GD-ROM drive with a functional one.
Secure the new GD-ROM drive to the console with the Philips #2 screws.
Connect the three GD-ROM cables to the logic board.
Connect the GD-ROM data ribbon to the logic board.
10 andere personen hebben deze handleiding voltooid.
Één opmerking
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
