Ga door naar hoofdinhoud
Sega Dreamcast GD-ROM Replacement
Wat je nodig hebt
  1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: stap 1, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement, Expansion Bay: stap 1, afbeelding 2 van 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast GD-ROM Replacement: stap 2, afbeelding 1 van 3 Sega Dreamcast GD-ROM Replacement: stap 2, afbeelding 2 van 3 Sega Dreamcast GD-ROM Replacement: stap 2, afbeelding 3 van 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast GD-ROM Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast GD-ROM Replacement: stap 4, afbeelding 1 van 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast GD-ROM Replacement, GD-ROM: stap 5, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement, GD-ROM: stap 5, afbeelding 2 van 2
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  6. Sega Dreamcast GD-ROM Replacement: stap 6, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement: stap 6, afbeelding 2 van 2
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  7. Sega Dreamcast GD-ROM Replacement: stap 7, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement: stap 7, afbeelding 2 van 2
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  8. Sega Dreamcast GD-ROM Replacement: stap 8, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement: stap 8, afbeelding 2 van 2
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  9. Sega Dreamcast GD-ROM Replacement, GD-ROM: stap 9, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement, GD-ROM: stap 9, afbeelding 2 van 2
    • Replace the bad GD-ROM drive with a functional one.
  10. Sega Dreamcast GD-ROM Replacement: stap 10, afbeelding 1 van 2 Sega Dreamcast GD-ROM Replacement: stap 10, afbeelding 2 van 2
    • Secure the new GD-ROM drive to the console with the Philips #2 screws.
  11. Sega Dreamcast GD-ROM Replacement: stap 11, afbeelding 1 van 3 Sega Dreamcast GD-ROM Replacement: stap 11, afbeelding 2 van 3 Sega Dreamcast GD-ROM Replacement: stap 11, afbeelding 3 van 3
    • Connect the three GD-ROM cables to the logic board.
    • Connect the GD-ROM data ribbon to the logic board.
Eindstreep
10 andere personen hebben deze handleiding voltooid.
Thorr686
472 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-1, Regan Fall 2009 Lid van Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Leden
21 handleidingen geschreven
Één opmerking
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 153
Altijd: 33,230
