Ga door naar hoofdinhoud
Sega Dreamcast Fan Replacement
Wat je nodig hebt
  1. Sega Dreamcast Fan Replacement, Expansion Bay: stap 1, afbeelding 1 van 2 Sega Dreamcast Fan Replacement, Expansion Bay: stap 1, afbeelding 2 van 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Fan Replacement: stap 2, afbeelding 1 van 3 Sega Dreamcast Fan Replacement: stap 2, afbeelding 2 van 3 Sega Dreamcast Fan Replacement: stap 2, afbeelding 3 van 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Fan Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Fan Replacement: stap 4, afbeelding 1 van 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  6. Sega Dreamcast Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  7. Sega Dreamcast Fan Replacement: stap 7, afbeelding 1 van 2 Sega Dreamcast Fan Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  8. Sega Dreamcast Fan Replacement, Fan: stap 8, afbeelding 1 van 2 Sega Dreamcast Fan Replacement, Fan: stap 8, afbeelding 2 van 2
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Thorr686
472 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-1, Regan Fall 2009 Lid van Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 18,715
