Ga door naar hoofdinhoud
Sega CD CD Tray Replacement
Wat je nodig hebt
  1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: stap 1, afbeelding 1 van 2 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: stap 1, afbeelding 2 van 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD CD Tray Replacement: stap 2, afbeelding 1 van 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD CD Tray Replacement: stap 3, afbeelding 1 van 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD CD Tray Replacement: stap 4, afbeelding 1 van 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD CD Tray Replacement: stap 5, afbeelding 1 van 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD CD Tray Replacement: stap 6, afbeelding 1 van 1
    • Lift the top of the case to remove the cover.
  7. Sega CD CD Tray Replacement: stap 7, afbeelding 1 van 1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD CD Tray Replacement, CD Tray: stap 8, afbeelding 1 van 2 Sega CD CD Tray Replacement, CD Tray: stap 8, afbeelding 2 van 2
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD CD Tray Replacement: stap 9, afbeelding 1 van 2 Sega CD CD Tray Replacement: stap 9, afbeelding 2 van 2
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD CD Tray Replacement: stap 10, afbeelding 1 van 2 Sega CD CD Tray Replacement: stap 10, afbeelding 2 van 2
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD CD Tray Replacement: stap 11, afbeelding 1 van 1
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD CD Tray Replacement: stap 12, afbeelding 1 van 2 Sega CD CD Tray Replacement: stap 12, afbeelding 2 van 2
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD CD Tray Replacement: stap 13, afbeelding 1 van 1
    • Carefully remove the CD tray from circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
sskyllin
21 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-14, Maness Fall 2010 Lid van Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 51
Altijd: 9,736
