Ga door naar hoofdinhoud
Sears Craftsman 315.109020 Motor Replacement
Wat je nodig hebt
  1. Sears Craftsman 315.109020 Motor Replacement, Motor: stap 1, afbeelding 1 van 2 Sears Craftsman 315.109020 Motor Replacement, Motor: stap 1, afbeelding 2 van 2
    • To ensure that you do not get grease and dirt on your table or floor, lay a towel down before you begin working.
    • The grease from the circular saw can stain your towel so a dirty towel or work rag is recommended.
  2. Sears Craftsman 315.109020 Motor Replacement: stap 2, afbeelding 1 van 3 Sears Craftsman 315.109020 Motor Replacement: stap 2, afbeelding 2 van 3 Sears Craftsman 315.109020 Motor Replacement: stap 2, afbeelding 3 van 3
    • With your Phillips screwdriver, unscrew all 7 of the 20 mm screws on the handle of the circular saw.
    • There is one 25 mm screw that goes in the hole circled in red.
    • Unscrew the forked screw head
    • Lift off the top half of the handle.
  3. Sears Craftsman 315.109020 Motor Replacement: stap 3, afbeelding 1 van 2 Sears Craftsman 315.109020 Motor Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the two wide-head 20 mm screws holding the remaining half of the handle to the motor.
    • Remove the remaining half of the handle from the motor by lifting it over the screw that is keeping it in place.
  4. Sears Craftsman 315.109020 Motor Replacement: stap 4, afbeelding 1 van 3 Sears Craftsman 315.109020 Motor Replacement: stap 4, afbeelding 2 van 3 Sears Craftsman 315.109020 Motor Replacement: stap 4, afbeelding 3 van 3
    • Using a crescent wrench, unscrew the hex washer head screw that is holding the blade in place.
    • Lift the blade over the internally threaded screw and pull it off of the saw.
    • If the hex washer head screw rotates but does not loosen or if the whole blade rotates as you turn your wrench, giving the wrench a quick jerk should loosen the screw.
  5. Sears Craftsman 315.109020 Motor Replacement: stap 5, afbeelding 1 van 2 Sears Craftsman 315.109020 Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the blade cover by applying upward pressure until it unsnaps from the washer.
    • The blade cover will come off easier if it is facing away from the rest of the saw (see second picture).
  6. Sears Craftsman 315.109020 Motor Replacement: stap 6, afbeelding 1 van 2 Sears Craftsman 315.109020 Motor Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the 70 mm screw that is inside the black tube (see first picture).
    • Unscrew the five screws as highlighted in the second picture. The bottom left is a 70 mm screw and the other four are 20 mm screws.
    • Unscrewing the remaining four 20 mm screws are unnecessary unless you wish to repair or replace the cogs in the saw.
  7. Sears Craftsman 315.109020 Motor Replacement: stap 7, afbeelding 1 van 2 Sears Craftsman 315.109020 Motor Replacement: stap 7, afbeelding 2 van 2
    • The motor will now be loose and you should be able to twist the motor in a counter-clockwise direction until it is able to be pulled off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Blake Avant
218 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-4, Green Fall 2015 Lid van Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 385
