Ga door naar hoofdinhoud
Sears Craftsman 315.109020 Blade/ Blade Cover Replacement
Wat je nodig hebt
  1. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: stap 1, afbeelding 1 van 2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: stap 1, afbeelding 2 van 2
    • Although this is not a difficult fix, it can definitely make a mess.
    • Lay down a dirty towel or work rag and place the saw on top of the towel.
    • Handle the saw with care and avoid placing your hands on or near the blade when possible.
  2. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: stap 2, afbeelding 1 van 3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: stap 2, afbeelding 2 van 3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: stap 2, afbeelding 3 van 3
    • Use the crescent wrench to remove the hex washer head screw and the washer.
    • Gently lift the blade up and pull it off of the internal threaded shaft.
    • If the hex washer head screw, or the entire blade spins as you turn the wrench, a quick jerk of the crescent wrench should loosen the screw.
    • Although many screws loosen in the clockwise direction, the hex washer head screw on this circular saw loosens in the counter-clockwise direction.
  3. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: stap 3, afbeelding 1 van 2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: stap 3, afbeelding 2 van 2
    • Lift up on the blade cover until it unsnaps from the washer.
    • The blade cover will come off easier if the bulk of the cover is facing away from the saw.
Conclusie
Blake Avant
218 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-4, Green Fall 2015 Lid van Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 1,044
