Ga door naar hoofdinhoud
Seagate FreeAgent Go Portable Drive Hard Drive Replacement
Wat je nodig hebt
  1. Seagate FreeAgent Go Portable Drive Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • This guide holds true for most all FreeAgentGo drives that have this body style
  2. Seagate FreeAgent Go Portable Drive Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • The first thing you'll need to do is get a spudger of some sort and get underneath an edge. It doesn't expressly matter which, I found starting at the front corner the the easiest.
    • Work your way all the way around the edges, the cover is being held in place by rubber cement-like glue.
  3. Seagate FreeAgent Go Portable Drive Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • As you can see here, the back edge where the light is has a small connector to the rest of the board. this pulls out easily.
  4. Seagate FreeAgent Go Portable Drive Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • The bottom casing lets the drive fall out and you have two metal shielding pieces holding the drive in place with four rubber bumpers. The USB dongle is held in place with tape, but it's easily pulled up and removed from the plug.
  5. Seagate FreeAgent Go Portable Drive Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • After the USB dongle is removed, there are four phillips screws on the sides that hold the two metal pieces in place. Once those are removed, the rubber bumpers are easily removed as they are only held in place by the cement as well.
  6. Seagate FreeAgent Go Portable Drive Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • The top cover slides backwards, away from the board to allow access to the 888GB drive. The drive pulls out from here and easily disconnects from the controller board.
Conclusie
8 andere personen hebben deze handleiding voltooid.
zenmastr
383 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 66
Altijd: 36,513
