Ga door naar hoofdinhoud
Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement
Wat je nodig hebt
  1. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement, Training Wheels: stap 1, afbeelding 1 van 1
    • Flip the bike upside-down for stability.
  2. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 2, afbeelding 1 van 3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 2, afbeelding 2 van 3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 2, afbeelding 3 van 3
    • Use a 15mm socket wrench, and remove the wheel arm bolt securing the wheel arm.
    • Remove the damaged wheel arm.
  3. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 3, afbeelding 1 van 3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 3, afbeelding 2 van 3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 3, afbeelding 3 van 3
    • To replace a damaged wheel, use a 13 mm socket and a Phillips screwdriver, and remove the wheel screw fastening the wheel to the wheel arm.
    • The screw may be hidden behind the bike's design theme. If this is the case, poke through the label to reach the screw in the center of the wheel.
    • Replace the damaged wheel and secure it with the screw you just removed from the old wheel.
  4. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: stap 4, afbeelding 1 van 1
    • Realign the wheel arm with the rear bolt placement and secure it with the wheel arm bolt.
    • Replace the damaged wheel arm prior to securing it in place.
Conclusie
Brian Gibson
109 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 102
